  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Sweet. So if your going to Collie can I grab a lift? I'll be at your place early:D
See'ya:burnout:
Only if you can put up with my snoring cos it's an o/night thing.
btw , I sleepwalk....
Cheers
Ken
Neo,
I hadn't thought about that, I'll save for a R32 GTR instead, Ken has influenced me:D
See'ya:burnout:
Another convert to the dark side
Come little one, for there is much to learn before the whale invasion.....
Cheers
Ken
Originally posted by Neo
See Ya Guys
My girlfriend keeps coming out and calling me names.
"Computer Geek Skyline Head Old Man "
bye
Keep her as your g/friend cos they can only ask.
Once married , they DEMAND !!!
cya Neo
Cheers
Ken
Night Neo.
Ken, Over night with you? I don't know if I could resist your charms:p
When are the whales invading, I'll have my harpoon ready:p
See'ya:burnout:
your driving one , shoot it now:D
Cheers
Ken
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
