lol @ paul... the 2nd run did it the damage - there was no problems after the 1st run.. it was fine.. probably would've made a month or more....
at least the old man offered to pay half.. :D looks like that flywheel will HAVE to go with the clutch hey?!? hehehe
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yeah I thought so.... yours had the "wing" license plate or something similar from memory.... It was very nice from what I saw of it... I hope it goes well when you get it back then... I was on that cruise but busted my clutch on the way there so had to go home early ..... If you could smell a car with a burnt clutch that day... that was me :D
Cam... that included all the labour as well.... it was the total price to pay.... I had the option for the heavier pressure plate but I opted for the slightly lighter option as I wanted my car to still drive like a stocker .... i.e no real heavy clutch work....
Yeah I was lucky..... I did search for a little over a month to find my line but this one had everything I was looking for in the one package.... and it was in great condition..... I have had absolutely no regrets buying this one!!!! Well apart for the fact its not an "R" but hey we cant have everything :D
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
    • I'm going to guess, likely headunit, and the twin cable likely went to an amp as a remote turn on feed.
