  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Sarah, the church gossip and self-appointed arbiter of the church's morals, kept sticking her nose into other people's business.
Several residents were unappreciative of her activities, but feared her enough to maintain their silence.
She made a mistake, however, when she accused George, a new member, of being an alcoholic after she saw his pickup truck parked in front of the town's only bar one afternoon.
She commented to George and others that everyone seeing it there would know what he was doing. George, a man of few words, stared at her for a moment and just walked away. He didn't explain, defend, or deny, he said nothing.
Later that evening, George quietly parked his pickup in front of Sarah's house... and left it there all night.
i think that would be great - but didnt he have a girl - remember seeing him with a chick once? i dont think she would remember him tho - she was too busy trying to keep herself upright!!
One thing that rexy piss me off is that...
when we go out, he is very shy boy so I talk to ladies in the club and do the all the work. but at the end of the night/ next morning he is the one who gets phone number/calls.
damm I put all the ground work then he gets the fruit...:(
NOT HAPPY JAN!!! it happend twice now...:)
what's with ladies? what? am I too forward? hahahhaha :D
you are a little forward joe haha - mels really shy too but total losers will come up and talk to her and she'll be too nice to tell them to F-off and after while i get sick of it and so i but in and rescue her.
So rexy's missus broke it up then?
oh well for the best i guess - no point doing the future thing if only one persons heart is into it.
Sounds like he really liked her tho :D Gave up a lot of time for her - thats sweet when they do that - u know they are really into - i dont know u can just tell by a person actions how much they like u :(
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
