Yep I will be back late tomorrow night...
The training has been pretty cool... the funny thing is though is that the training is for a specific piece of equipment that we only have in Melbourne and Sydney.
So basically I do the training for the equipment then go back to Perth and never use it :(
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yeah for sure... Free trip.... Free hotel ..... A Bit of a wander around a new city.... A week off work ( Well training is a bit of a holiday :( )
Hehe I have only seen Mel when she's drunk and when she's hung over ... Both ways she is funny :P
Originally posted by GTS-t VSPEC
Ken, Just incase you needed some advice and wanted to talk to me:p
I should be sorted by early next week:D
The quick engine out and back in on the R has got bigger than ben hur.
The Albany w/end competition could be in jeopardy atm.
Bugga !!
Cheers
Ken
Nope, bailed the car to CRed due to a lack of time and Lumpy owes me a favour.
Pulled the engine out and has too much blowby.
Am sourcing the forgies , metal h/gasket etc as we speak. I think this thing is gonna be a rocket ship when finished and will look cool with the blue rocker , polished trust pipes yada yada..
Cheers
Ken
Ken, It would suck if your not going, but we will anyway, we have other accomodation already booked:D
No will still go but may have to find a backup plan if the engine is not back in time. Has to be machined etc , assembled and run in.
Can see me running it in by driving to Albany.
Lumpy won't let me have the Autronics on till the engines bedded.
Untrust worthy bastard.:(
Cheers
Ken
All it takes is pre planning .... just work out how long you will be gone then work out how much higher than 100ppd you need to not post in the uk and have the average to drop to the 100ppd and then get to that point before you go :(
I hope that made sense.... I am now hell tired and am going to bed... it is 1.15 and I will have to be up around 7.00am... so thats just about it for me.....
I will chat with you again on Monday hopefully :P
Bye bye
Mmm, sounds good Ken. Blowby from ring-lands? A bit of money to spend, but it should be able to withstand the extra boost from the 581's:D
Yea , I had my suspicions when it popped the dipstick out once.
It's not like I thrash it around a race track or nuthin...
Cheers
Ken
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
