  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
4 door gtr, only the original autech would be worth it :) lol hehehe maybe when i have a family :)
hey niz, more pool cleaning action yeah? i be over soon :P
paulie, yeah i am coming to dinner and movies :) , why u going to works and sst tonight?
adrian :D
