haha Nah Ken ....... the shit you learn about ya coworkers when you get them to burn a disc for ya and they decide to add "extras" disturbing thing is - ive been looking at this shit for two hours and im only up to "H"
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Hmmm , might have to have a vid night....;)
Ohh , and hi Bam , good to see you back. When and where is this store opening ?
cheers
Ken
yeah sure have a vid night if u want to see a cat murdered and a guys head getting chopped off .............. charming.
Wrong cat , was more looking at the big headed one.;)
Cheers
Ken
Originally posted by G0DF4Th3R
Ken - basic stuff all done, just need the final capital injection (goodbye R33) and then should be in business mid Sept
it'll be in JB around 2.5 hours south of KL and 5 mins from Singapore
JB ??
So does this mean you're moving back to Malaysia ?
And what sort of shop ?
Cheers
Ken
just came across something u would like Ken .... lets just say Oyster advertising aint what it used to be .....
Oysters ??
Aren't they something you eat ?
Or is this some weird name for an obscure sexual deviancy I ( surprisingly ) don't know about??;)
cheers
ken
water ...... im sitting here with my legs firmly crossed ..... its like you guys watching a clip of a guy getting kicked in the balls 50 times ...... ouch ..... gross ..... why would anyone want to acheive that i mean you would be left so loose there would be no sensation.
sorry was on the phone
Ken - i will be a silent partner in the business. day to day running will be done by my best friend (payroll) and his bro (major shareholder). also the owner of one of the largest car accessories shop is a minor shareholder as he is moving into the performance end of the market. he also needs me and my best friends bro as we are Malays and are eligible for tax cuts/benefits and he is Chinese so he needs us. we need him coz he has been in the business for ages and has an established name
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
