  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Ken, Just looked at the Drag calander, it's only Sunday Drags till the 1st of Oct, then Wednesdays start again.
Bugger, Every Sunday is booked for me until we get back from SA.
I have a GTech.
If I knew how to use it , maybe we could do some testing in conjunction with Micko and Danny , a straight quiet road and some two ways....
Cheers
ken
Ken, Niz's brake lines are broken, any good place to get a replacement?
Broken ??
as in split in 2 or just have some cracks on the outer casing ?
Cheers
Ken
Originally posted by G0DF4Th3R
so anyway, this guy with the GTR asks whose GTR is the quickest in Perth and how he's gonna go down to the Plex soon
and he boosts at 1.7
Hi Bam
The place is full of tossers.
Boosting at 1.7 bar is out of the efficiency range of most bolt on HKS twins.
Mind you , if he has a big single then I will shut my mouth.
btw , I think 11.5 from the Speedworks R34 is bout the quickest
Cheers
Ken
No worries Mat, more than happy to help, better than working:D
Ken, She had her disks skimmed, when they moved the calipers the brake line snapped, but there was obviously an old fracture in the line and it was squashed out of shape.
Bam, Quickest is a low 11 I think. 1.7bar isn't that much.
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
