>>> Foote, Melanie (Australia) 13/08/2003 9:11:42 >>>
i got caught by my first speed camera last nite!!! :mad: the thing was i wasn't
actually speeding, i just sped up to overtake someone. damn it!
^ im going to use that excuse next time .... "Sorry officer ... i just sped up to overtake everyone"
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
because i had an idea of how all this was suppose to work and now its just been phucked so im sulking thats why. Not to mention it just proves a point that i think ive already knew all along :mad:
Besides nobody invited me on Saturday in the first place so im not likely to go now just cos you thought you would invite me cos im chucking a tanty - you guys can do your own map.
im going to buy other paul a carton of beer for my brakes :mad: i think its the polite thing to do considering all that time and the fact they didnt charge for parts.
Did you get the price of the redline oil i got for you
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
