  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
ok - as pm'ed to Sydneykid:
Firstly, I will describe my car:
Series1 R33 GTS25t
Mods:
HKS EVC4
3" Turbo back zorst
CAI pod filter
NGK coppers @ 0.788gap
Cleaned induction system - AFM, TB etc.....
Ok, when boosting at 3000rpm/0.82bar i get a slight ping, only audible between those concrete barriers on the highway. I turned it down to 0.76bar and its ok. Whats causing the ping at low rpm? I've done a search on SAU and can't really find any specific info applicable to me. The problems i can think of are:
1. Dirty injector(s)
2. Tired fuel pump
(dont think it the first two coz it seems to be ok up high @ 0.76bar)
3. Turbo is getting hot at those low rpms (fix with FMIC)
4. Just bad fueling/timing coz of stock ECU (temp. patch with adjusting the CAS or get an SAFC as a temp. fix)
5. Blow by gasses leaning it out?
6. Try a colder plug (what do you reccomend for my application)
Could I just reset the ECU so it will learn the increased air flows?
Ross, Are you 100% it's a ping? I run BCP7ES plugs, there a heat range colder than the 6's, gapped to 0.7mm. Stock pump could be going, but you'd expect it to happen under full-load. Might be worth getting injetors flow-tested. Blow-by is more likely to happen at high-rpm.
I'd get it on a dyno, and make sure that it is a ping, then look at the AFR's there the most likely indicators:D
Thats the only time it audible - when the sound bounced off a wall. What else could it be? I think your suggestion for a dyno si the best, that way I can see EXACTLY what the problem is. Hate to buy an FMIC and find out it was just a dirty injector eh.....
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
