  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Not to bad, yourself Cam? I have been over in Canberra with work, been back for a couple of weeks. Was going to do the SKills swap thingy but I was playing Offical at the Classic Rally for the last 3 days, and yes lots of rain. The beasty was nearly sold for GTR R33 but deal has fallen through, now need to fix turbo and get back up to speed, but enough about me hehehe
Whats UP dude, do you know much as to PAS??
GTR 33? Nah - stick with yours. RWD much more fun. :P
Me - not much. Bought a house, been flat out at work, been thrashin the car.. usual stuff..
PAS - nah, not too much. I'm not going near it with my car anymore. Need the $$ for my house. Maybe next year if I can do the things I want to.. mmm RB25/30 engine... :)
yeah got ya, check out your style in the drift thread, nice work.
I should have brought a house by now but still happy living the good life hehehe
RB30 donk will give you heaps of torque mate, go wild.
Yeah, notice that cars are pulling out left right and centre of PAS, but you know me, love that shit hehehe (you know the theme they are going to run?)
:headshot:
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
    • Finally back on the ground and once around the block for the first time in 2+ years
    • Ok a solution was found. I had left the factory oil temp sensor in and it was hooked up. My car never had the triple gauges.  Apparently when you delete the factory pressure and leave the temp sensor connected it triggers the oil light on the dashboard. Disconnected the temp sender, no more light.  I still haven't gotten around to look at the diagrams to figure out how/why they are tied together.
