  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
LOL ... guy friends thats worse!! :( Friggin Jules was messaging me all sunday ..... its liek god damn boy leave me alone for 5 minutes .... i aint driving all the way out to the Vines for a bourbon with ya! Not that i even drink the stuff.
is that the quire one? hahhahahaha.. lol
I like girls as friends, you can get a lots of tips :D
Nah Joe. ... thats Jared .... Jules is like Mafia .... thats why if we catch up its always in public place away from his house .... cos lets just say i dont want the police tailing my car for the next two weeks. Actually how the hell Jules n i ever became friends is a mystery ... but he's a good person to have around.
hahhahahah lol you are now target!!!
does he also sits wall behind in the public places? and always look behind every 5 minutes???
typical sign of drug dealers LOL
