I remember seeing a thread about this a while ago, but my search turned up fruitless :) please don't kick me for posting this up again. Also, if there is anything here I have said that is wrong or dumb, please correct me by all means.
Just got an Oil Catch Can which appears to be hollow = "unbaffled"? Reading up on it, this means that the can is pretty much pointless ~ not good!
Someone said that steel wool in a stocking stuffed inside will solve this problem. Is this what baffling is? If so, what type of steel wool - what type of stocking :D And is it literally as easy as stuffing it into the can somehow?
Thanks all...
PS: Some of the cans I have seen have a filter on the top of it... does this filter have a purpose? I might think about modifying the can to fit a small K&N in there as well (good/bad, you tell me)
https://www.sau.com.au/forums/topic/88559-need-some-knowledge/
You need to make a divider which seperates the inside of the can into 2 halves, one half for each hose. This is best made from thin alloy...
At the bottom of the divider you should drill some holes for the air to go though, note these holes should be at the bottom as it forces the air to go through the stocking which is the next bit.
Stuff some kitchen scoures (spelling, you know what I mean) into stockings, tie them off a put one in each side of the catch can. Dont use steel wool as it can rust!
The stocking should catch the oil but let the air through, so now you have an oil/air seperator :D
So its empty and you cant open it?
My Greedy one has alan keys to take the top off. Where are the locations of the hoses connected to the can? If they are at opposite sites to each other then I guess you could just shove the stocking in between them.
A pic of your catch can would help...
I'll post a photo up when I get home tonight... can't do it right now.
Yeah, the hose connectors are right opposite each other - the design is just like a Cusco can. Even if I can't make the divider inside the can as you suggested, you rekon it's a good idea to just stuff the can with kitchen scouers in stockings?
Here you go matey... photos!
Mate, are you sure that you cant open it. I'm just asking becuase it looks to me like that bracket around the top might come off or something. If you cant open it and put a seperator in then I would get one of the readline filters to run off one of those outlets, note this is not legal though but it would stop oilly air going back into your intake...
Juts shoving the stockings in through the little hole wont work very well for two reasons:
1) The air is not moving through much of the filter because those outlets are very close together.
2) It would be an absolute biatch to get the filter out when it needs to be replaced.
yea put the filter on one of the blue nozzels. You should be able to get the little filters from places like autobarn etc etc. There is a really good thread on setting up catch cans by sydneykid on here somewhere, try to search for it as it will be a good guide for ya.
My catch can is set up to plumb back into the inlet which is the legal way but if you have a hose from the one of the blue nozzels then connect the little filter somewhere burried in the engine bay then you should be right :(
This is what you need to do:
See the hose comming from the cam cover to the can, yours should be the same. With the one comming from the can to the inlet, instead of running the hose to the inlet run it down into the engine bay so you cant see it then put the filter on the end of it.
Try to find SK's thread as there are many ways to set this up depending on how you us your car. eg, PVC valves block etc etc.
PVC would be a good place to start your search... OR is it PCV Sorry I am not sure...
Edited by GunMetalR33
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
