Well, I am over 25 thankfully...but still Shannon's quote is higher than Just Car. Which one is recommended though in term of trustworthyness?
Btw, just finished talking to both Just Car and Shannons. They seem to be unaware that the VIper/Clifford is not of Australian Standard. LOL
And the code for Australian Standard is:
AS/NZ4601
I guess at the end of the day the question is, will they make it a big deal if so happens that you car has Viper and got stolen?
shannons told us we need to fax through a receipt for the alarm
*paying about 2.3k for a 23yr old rating 1 for a 32 (practically no diff in $ with gtr/gtst).
i think they both said they wont insure a remote start alarm either (but not 100% sure on that). I think they wanted a 3point immobiliser from memory.
Main difference between shannons and just cars (imo) is shannons = lifetime guarantee on repairs, choice of repairer .. just cars = 3yr guarantee, must match or beat quote from one of their approved repairers if you want to fix elsewhere (bit of a F around).
I think Shannons is better.. even their home insurance covers specialist tools in a garage.. but their quotes are double Just Cars (but we are both under 25).
blackskyline: what about if you swap the viper wiring harness to a black one? Surely that would make the alarm acceptable? (was thinking about upgrading to viper.. maybe not!)
Was thinking of changing the cables to black. But that doesn't make the viper an australian standard.
I've talked to few of my friend who owns a audio security shop and they mentioned that the australian standard alarm like flashpoint, mongoose, etc are not even half as good as the Viper or Clifford in terms of module and functionality. They are only better in terms of the black cabling. That means, you car *MIGHT* be safe from stolen but not necessarily safe from breakins. I find that is is plain silly that the insurance company accepts crappy alarms but rejects the top of the range ones.
It is sad, I'm gonna have to switch to a crappy alarm product (or even just put in a plain OZ standard immobilizer). Or alternatively, change my comprehensive to third party and put a top of the range alarm.
Its not as simple as changing the wire :)
wont change the model number of the alarm!
My good mate does alarms. He can get something to work for you if you want? PM for details. He comes reccommended by many :)
They can be safe if you do them right. I mean 3 (or 2) points of immobilisation is just that. It doenst matter if you spend $300 or $700
You just get funky stuff like shock sensors which wont save your insurance bill. Or make the car any less stealable :)
BAH! There ought to be a sticker checklist (or something) on ALL car parts that stores have to complete before sale.. ie
Is this Aus standard? y/n
Is this an illegal mod in the state of .....? y/n
(Is this overpriced/gheye and nothing but wank factor? y/n)
And so forth...
Might make it a little bit clearer and make more people impulse buy.. rather than "may not be legal for street driven cars" or whatever (ie check at your own leisure).
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
