So who is going:
FOR MORE INFO AND ENTRY PLEASE CONTACT:
BETH WILLIAMS (07) 32097589 (SCHOOL) 0410471044
FAX:(07) 33880500
E-MAIL: [email protected]
Shailer Park Show 'n' Off
Shailer Park Primary School, Bulwarna St. Shailer Park
Sunday 16th October 2005, 9:00am - 2:00pm
Includes:
Show and Shine
Ute Show
Motorbikes and Trikes
Club Challenge
40 Trophies up for grabs
Live Entertainment
Food and Drinks
Kids Entertainment (rides)
Sound off competition
Club Challenge:
Best Club Display
Best Represented Club
Individual Entries welcome
Competitor Pre-Entry $15 (includes one passenger)
Entry on the Day $20 (includes one passenger)
Additional Passengers and Spectators $2 per person/$5 Family
Competitors Entry via Everlast St (off plantain rd)
Entrants from 7am
Judging commences at 9:30am
https://www.sau.com.au/forums/topic/89133-shailer-park-show-n-off/
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
