i was wondering what everyone else has
Ive goT a
DXZ956MC clarion Head Unit
TS-C160R Fronts speakers and amp pioneer.
TS-D161S rears
GM-6100F speaker amp
SWR-1222D sub im using a low power amp so the 2ohms is much
MRP-M350
https://www.sau.com.au/forums/topic/89253-people-audio-stuff/
Source: Clarion HXD2
Processing: Zapco (SymbiLink)
Amps: Zapco C2K-6.0X's
Front: Rainbow Reference 6.5" midrange, Morel Supremo tweeters and Boston Z ambient tweeters.
Rears: Toyota Soarer 6"
Subs: Diamond Audio TDX12
Cable & Deadening: Streetwires / Stinger.
Batteries: Stinger SPV44 (front) / Optima D34M (rear).
Source: Clarion DRX-9255
Processing: Orion Concept 97.2 (Limited edition DEQ30) completely digital EQ and Phoenix Gold Zeropoint ZPX2 3way Balanced xover
Amps: Phoenix Gold Zeropoint ZPA0.3s
Front: Dynaudio System240mkIIs. soon to have esotars or morel supremos added and the original tweets moved up to ambients.
Rears: no way!!!!!
Subs: Sold my adire audio brahma. still looking for new sub.
Cable & Deadening: Stinger/Van Den Hul/Monster Cable/+custom made stuff
Batteries: Optima D34
and none of its installed!!!!! :unsure:
Edited by djhatton
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
