I have Nokia...
7210 $100
7250 $200
Rs,
David
0400261099
sorry mate you better do your research as that phone is about 2 years old worth no more then about 80 bucks!!!
if you see the above post someone is interested in selling me the I version for 150!!!
and you are selling the lower version for 200
sorry mate
same with the 7210
i will offer you 150 for both if they are in boxes cheers
  • 3 months later...
