  • Replies 625
Posted Images
not washed, not planning to either
gonna be a good day.. and Miss Turbo.. please change your name for the day
haha no problem :) (I have a white r33 s1, and my names liz too... spooky)
wilch wanna come wash the car with me tonight?
I'm going to that Dural carwash place at 7pm.
Damnit! Only just saw this! Just came from there too. Amanda and I just dropped off a dvd.
Went to the UAS 300zx dyno day today too. John came up to my car and said, "hey, what the hell are you doing here? It's a zed day today!"
LOL
lol
thats bs
ill put $10 down that you will turn up sunday with a washed car!
you owe me $10! :) :lol:
LOL
double or nothing, who gets more power at next dyno day
:wub:
my cars insured
my alarm is installed
I will be there tomorrow
but not crusing
just meet and greet
nice~~now that s what i m talking about.... :)
i will be doing exactly the same thing
Precis for Saturday
Sydney: Chance afternoon shower.
Liverpool: Chance afternoon shower/storm
Penrith: Chance afternoon shower/storm.
Richmond: Chance afternoon shower/storm.
UV Index: 7 [High] decreasing to 5 [Moderate] under cloud.
For Sunday
Fine. Mainly sunny. N/NE winds.
Precis For Sunday Min Max
Sydney: Mainly sunny 15 25
Liverpool: Mainly sunny 13 26
Penrith: Mainly sunny 13 27
Richmond: Mainly sunny 13 27
yep, for sure... me against Silv next year.
Highest power wins.
I'll be in this for sure! RB25det vs RB20det, and a big ass turbo on mine..
Double or nothing. You're on. :)
What about me huh???
*makes chicken noises* :lol:
my car is clean.... was out in my mates 350z today getting it wet and dirty just after it got a nice professional detail... ouch....
doodz im following u there tomorrow i got no idea on where we are meeting..... wat time u leavin?
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
