It's not heaps... just a very very fine coat of soot ~ doesn't piss me off about the richness since I'm now getting about 400+ per tank afte SAFCII, just pisses me off that i have to clean the rear bar each time :(
bitch bitch bitch... try having VTEC and a Honda ECU dude... VTEC = puff of brown smoke at ~5250RPM... my bar is ALWAYS sooty! :D
Honda ECU... you add any mods - it keeps the a/f the same! CAI... Exhaust... to make it run a bit leaner/more efficient - etc... it'll change it back to stock a/f ratio! ;)
  • Replies 625
Posted Images
Did I mention it backfires constantly when I go off the throttle and it's been spooling hard.. not good ;) think it's excess fuel just getting dumped into the dump-pipe which ignites instantly.. sounds like someones making pop-corn just under my feet..
have the same thing
Thank you liz.. you just put my mind quite at ease.. it's not good is it.. just give it a bit of throttle and it's happy.. I think it's because it kills ignition but doesn't stop fuel getting dumped in.. than it hits the turbo dump pipe and VOOMPH! it's pops..
john ...sorry...my cb didnt go far eunf.....dacow in the integer was ahead of us and he call me to warm about the copper.....so i mention is on the cd..but i think only some can hear me
your cb wouldnt have worked that good, considering i dont have one. lol
i think ill invest in one next cruise
When using the CB you have to make sure you don't have code sequencing on - it usually appears as a second little number next to the channel..
What this does is it only lets you receive from people with the same code.. which means you won't hear anyone on the general channel..
just a piece of quick info..
If I recall he was in a very pimped out looking R34 4-door that my friend and I both commented on - man that thing sat sooo well on the road when we were cruising along behind you..
What suspension setup does it have..
i think i was between u and that wigga mobile for a bit... that thing didnt roll at all!!! i was all over the shop and he was just crusing along.. another photogropher that i was near ;)
loving the pics from everyone.... maybe there should be a SAU pic competition :D
man i think i respray my car...i am starting to get a headache now!!!!!  everywhere is yellow!!!!!!!!!!!!arggggggggggg
Yeah, I was going to go Yellow, but I have started to see it everywhere..
Ill keep it black for a little while :D
lol..
I think that was me.. also managed to kill the spider that was climbing on your from one shoulder to the other before we left..
hope you had a good day enjoying getting driven around rather than you driving all day..
That damn water at maccas, was bloody room temperature so we spent the day hunting down cold water..
your car looked nice.. made a couple of pics in the carpark :D ..
Edited by Links
Sorry silver about not being able to warn you earlier.. I didn't have anyones numbers except for mintie's! I thought you guys were in one group and would have heard :D
:D
lol..
OMG~~the spider thing was u as well?can not believe u saved me twice on the same day!!!(from the spider & thirsty~~~)lol
yeah my car will looked better after i fix the dent
what i mean before is that on the way back when we were all turning right to 'newcastle / scenic route' i went sttriaght ahead.. so tthen i took the 1st turn off and then went the other way (kamakasi style) then turned around when i saw yas all :D
also pm link video .. im dude in yellow r34 for those who are wondering
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
