By the way I was the guy who phoned you last night, I found in another post that you had problems with the diffs and hicas, did you fix these???
Yeh dude dunno where you got them from....the HICAS has never had a problem, and the diffs werent a problem it was the CV joints which have been fixed. That was done right away when I bought the car.
$22,000 still for sale.
  • 1 month later...
