Excelleant, good info, how old is " the older soundstreams"?  Is my 6 year old one old or new?
:D cheers: )
If the amp is blue, then it's "older" :) The newer ones are all sorts of colours and for the most part have cast critters on them like spiders or what have you.
The older blue ones were incredibly over-engineered, I have a Reference 300 two channel unit "officially" rated at 37.5W per channel ... but can be bridged to 1/2 Ohm at about 300W:)
The reason the new ones aren't as good? The company went bust and I don't think the new owner of the name doesn't make them in the USA any more.
  • Replies 57
If the amp is blue, then it's "older" :D  The newer ones are all sorts of colours and for the most part have cast critters on them like spiders or what have you.
Oh goody, mine is a blue one. Thanks for the background.
:) cheers :)
;) cheers :)
Hey SK, I thought you were a 'colour conscious' sought of guy - but a blue amp and 'peach' wiring on the SITC. A bit of a colour clash.
By the way 'off topic' received my SITC from ALEXCRIM today.
Marc2
  • 11 months later...
a sub will NOT fit under the drivers seat mate. NO WAY.
Ive got my amp under the passenger seat, all fine. Just have to block up the stock vent in there with some tape over it.
Easy to run wires too as the carpets already got a hole in it for the vent.
Only issue i dont like is that rear passengers feet can hit the amp, but I always warn people anyway.
yes i meant amp not sub under the seat
what I am really hoping for is some inspiration for a design for my boot that will give me max space but also good performance
any pictures of how people have set up their system would be muchly appreciated
thanks in advance
glenn
I'll get you some pics :P
I have a double sub box with two amps attached to the backs of the seats. works really well.
I also have an Alpine Media Centre D300E
Actually Glen, noticed you are SOR... You can see it in the flesh if you like, I"m kid free from 8am this morning lol to Sunday arvo..
my sub is at the back left hand corner of the Stagea, sits nicely between the rear of the wheel-well and the wagon door, strapped down, with the amp bolted to the back.
will post a picture for you when possible.
This is the sub box and the amps are just behind onthe backs of the seats. One amp is bolted on the 2 seater, and the other sits freely behind the other.
I'm going to get them attached to the back of the box at a later date.
The cargo barrier is upside down and is off a Falcon.
It isn't permanently bolted down as you can see, I have clips for easy lifting and its hinged... if I need to get to the space saver spare wheel.
The only reason I have the cargo barrier is to keep the dogs in the back without destroying the subs :laugh:
I will take more pics after work.
:O
Kylie
Awesome .. can you get some close up of the barrier & how you botled it down. I'm def interested in getting one so l can take my dogs with me, and not have them climb over my new seat covers.
They are nice sounding subs, those DVC kenwoods, stageagirl... Best you can get for $250.
I had keyed my stereo in the "whats the damage" thread, but here we go -
Head unit - SONY CDX-GT700.
Streetwires RCAs and 0GA power and earth, 12GA speaker cables
2x Aepro 1-farad capacitors (PS54S...?)
4x Pioneer GM7200M 800W (25WRMS) monoblock amps
2x Pioneer 300C 1000W (400WRMS) subs
1x Pioneer GM 600F Four channel amp
Focal 165CA1 2 ways in rear doors
Focal (lost the box - no idea on code) Splits in front doors.
Pretty beefy system that pumps out good SPL, but is also a very nice, crisp, clear sound. Very punchy, even from a distance.
Currently i have:
Panasonic CQ7401 headunit
DLS reference MS6 fronts
Kicker S10L7 10" sub
a fusion fp1404 powering the fronts
and a pioneer GM-D510 M powering the sub.
Havent actually installed the DLS speakers yet as i just bought them.
Pics for interest.
Some focal 165A1s that i used to have and also some JBL power 6.5s
Didnt like the focals at all and the jbls were okay.
I don't know what else I have.. there are tweeters in the doors with some other speakers and I have two huge amps..
Fuzzy I'll get some pics for you soon. Its a bit dark but I'll see how good the flash works on the camera.
My g'fs other half fitted the barrier for me so if it looks rough... lol
tweeters
Should of started a new topic.. sorry all.
This is the plate for the barrier.. there probably are others that fit, but this one does... upside down lol
Next is the base attached like so...
And this is how its attached at the top. We cut into the handthingy to use the bolt. I also think a stronger bolt was used too.
Excuse the dirt. I bought the barrier second hand for $150 in Kalgoorlie and I haven't removed it to clean and paint it YET!
I just bought a new head unit today, never heard of the brand before but it plays mp3, dvd, all the stuff it needs to has a 3.5" screen and is a single din.
Nothing really wrong with my head unit now except for the fact it wont play my cd's have to use the stacker all the time.
i have two 12" fusion powerplant subs in my stagea running a jaycar monoblock amp.
they are set up similar to how kylie has hers, and they pump out 136.8 dB... way too loud for me to listen to comfortably
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
