  • Replies 59
Mark the front wheel looks like it's turning. you'd prob be better off using the same wheel you used on the rear instead. Then what you should do is adjust the color balance levels, as you can see they look a bit green.
Let me help those in need -
Dark (this is yourself)
, (A punctuation mark used to indicate a pause or separation)
How (In what manner or way; by what means)
do (To perform or execute)
you (Used to refer to the one or ones being addressed)
go (To function properly)
at (In the activity or field of)
spot (To detect or discern, especially visually)
the (Used before a singular noun indicating that the noun is generic)
difference (The quality or condition of being unlike or dissimilar)
in (Within the limits, bounds, or area of)
the (This time used before singular or plural nouns and noun phrases that denote particular, specified persons or things)
weekly (Occurring, appearing, or done once a week or every week)
papers (A newspaper/s)
? (A punctuation mark placed at the end of a sentence to indicate a question)
Have we met an understanding yet ? (don't make me explain that one ...)
i will fix the sentence for you!!
ORIG: Dark, How do you go at spot the difference in the weekly papers ?
FIXED: Dark, How do you go at spotTING the difference in the weekly papers?
1 thing i dont get is.. what weekly papers.. and what difference?
    • Would be easier to just run the RB25DET gearbox, all you would need to do is have the tail shaft / prop shaft shortened. S15 uses the rear ABS diff sensor for the dash speedo, so you can skip using the gearbox speed sensor.
    • Was the failed sensor by any chance this one? Did it just fail or start pissing on itself? I ordered one too, for fuel pressure monitoring, and now I am hesitant to put it in, hehe. Where did you find a brand one?
    • You'd be insane, when a brand new 8HP is ~$4k, and all the work to put a 6 in would cost the same as an 8 and the 8 is a completely established swap. If you think that getting a cheap Falcon box is going to make it a cost effective exercise, then you're not accounting for the extra $10-15k that the task will consume.
    • any further information on this? also interested in putting a zf6 in behind a rb30!
    • They're all horrible. X-Trails have had a nasty sounding 4cyl since forever, no matter what engine family it came from. The CVTs only made that worse. Then the whole Renault thing only made every Nissan that was contaminated by them even worse again. The only fun I've had in a X-Trail was having it blown sideways across a frozen Minnesota highway at 90 mph trying to make it to the airport to get out of the frozen hellhole of Hoth. Nearly died. Was great fun.
