HI Guys, Im having a slight problem with my clutch - In my R33 GTST.
Its a Excedy 400HP CLutch, I think its 5 puck single plate (Brass Button).
It usally starts to grip Half way when releasing the clutch,
Now is right down near the floor, and has an awkward feeling.
The clutch shouldent be worn, its only around 6 months old and hasnt had too hard a life. even tho it should handle it, my car isnt much quicker then stock, only basic mods,
Any idea what it could be?
https://www.sau.com.au/forums/topic/91030-clutch-problm-r33-gts-t/
Any one know? or had this problem before? simple fix?
