Hi all,
New to the forums. Just thought I'd drop a line to say hi.
Pick up my R32 GTS-4 on thursday and looking forward to some cruises soon.
Cheers,
Shaun
Welcome Shaun!
I get my GTS-t on Thurs too! Can't wait...
Hope the public holiday doesn't slow things down!
Todd
https://www.sau.com.au/forums/topic/91538-new-member/#findComment-1649927
Yeah I can't wait either. It's all here and ready to go. I'll live in it for a week! lol
Know what you mean... I have waited 6 weeks for it to be imported so I am really itching!!! Plus I have been driving my RBgemini from A to B in the mean time...
Ohhh, I can't wait!!
Did you buy that one from Launie??
Todd
https://www.sau.com.au/forums/topic/91538-new-member/#findComment-1649948
Nah from hobart. Only imported 4 months ago. Owner decided to upgrade to a GTR so I got the GTS4 for cheap.
Sweet, can't wait to see it! Enjoy, will PM you when mine arrives... you should send me some pics when you get it and we could go for cruise.
Todd
https://www.sau.com.au/forums/topic/91538-new-member/#findComment-1649970
Hi all,
Cheers,
Shaun
Welcome to SAU Mad.
No doubt see your car around the traps sometime soon.
You will have to try and come along to a Wednesy night cruise or the Friday night meet ups :)
Cheers B
https://www.sau.com.au/forums/topic/91538-new-member/#findComment-1650734
Hi all, Here are the pics of my new baby.
When and where are the Fri and Wed night cruises on?
Cheers,
Shaun
Looks sweet dude!!!
Here are a couple of mine...
Not sure about the Wed cruises but 9pm Fri and Coles Kmart Car Park... Last night was pretty big!
I will give you a wave if I see you!
Arn't they just a load of fun... and so solid to drive!
Todd
Edited by CATKICKER
https://www.sau.com.au/forums/topic/91538-new-member/#findComment-1675391
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
