Hi All,
My gf is selling this car.
I thought y not advertise here first!!!!
Please lemme know if any one is interested
Pictures available upon request.
E mail on [email protected]
Vehicle 1999 MITSUBISHI LANCER CE II GLXi
Price $12,500
Kilometres 69,000
Body 4 door Sedan
Colour Metallic Green
Interior Colour Grey
Transmission 4 speed Automatic
Engine 4 cylinder U Multi-point injected 1.8L (1834cc)
Reg Plate PKM 807
Reg Expiry JAN-2006
Road Worthy Certificate Not Applicable
Brief Comments Excellent cond., low kms, full service history, under extended warranty
Long Comments This car is in excellent condition. Sparkling clean inside out. Female driver, very low kms. Still under extended warranty Fully loaded model with 6 CD stacker, spoiler and sunroof 4 Door automatic sedan. Full service history. Registration valid till Jan 2006. Very economical on fuel. Its the perfect car which needs no work and drives like new. Selling as getting a company car
Seller Details
Name Sunny
Suburb Heidelberg
State Victoria, 3084
Mobile Phone 0421007482
4 Speaker Stereo
Air Conditioning
Body Colour - Bumpers
Cd Player
Central Locking
Electric Mirrors
Electric Sunroof
Engine Immobiliser
Intermittent Wipers - Variable
Log Books
Power Door Mirrors
Power Windows - Front & Rear
Power Steering
Power Windows
Radio Cassette
Rear Spoiler
Remote Boot/Hatch Release
Remote Central Locking
Remote Fuel Lid Release
Sunroof
Tacho
Tilt Steering
https://www.sau.com.au/forums/topic/91544-mitsubishi-glxi-1999-fully-loaded/
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
