I am selling my R33 SKYLINE GTS-25t M-SPEC.
This car was imported at the start of 2001 and was first registered on 26 June 2001. I have the original receipt from this sale – the car was purchased for $31,000.00 with 45,000 KMs. The car now has 70,000 KMs.
This car is not daily driven. I have a few cars and drive this one on weekends only. I have only travelled 10,000 KMs in the past two years.
The car is 5-speed manual and turbocharged.
Now for the exterior. This car has a full bodykit. This includes:
  • Trust front bar.
  • BN rear bar.
  • BN side skirts.
  • Vented carbon fibre bonnet.
  • Bomex mirrors.
  • S2 rear wing.
All paint and panel work is by M&C Doyle in SA and is only one week old. This car does not have one single scratch or paint chip on it.
The car has had the following modifications added, all purchased new and fitted by CRD (NSW) or Tilbrooks (SA).
Modifications include:
  • HKS 3-inch turbo back exhaust with high flow cat and 5-inch HKS Super Dragger.
  • HKS Power Air Filter / Pod.
  • HKS front mount intercooler.
  • HKS oil catch can.
  • HKS oil filler cap.
  • R33 GTR V-Spec. fuel pump.
  • Nismo radiator cap.
  • Front strut brace.
  • NGK Iridium spark plugs.
  • Exedy heavy duty clutch ($900.00 and approximately 5,000 KMs old).
  • Lowered TEIN suspension.
  • 18-inch DTM rims.
  • R33 GTR brakes.
  • ECU chipped (in Japan).
  • Autometer boost gauge (A-pillar).
  • Apexi boost gauge (disconnected).
  • Greddy turbo timer.
  • Illuminous dials.
  • Skyline floor mats.
  • Chrome door sills with Skyline engraved.
  • Momo steering wheel.
  • Interior trim in excellent condition (low KMs).
  • Tinted windows.
  • Pioneer DEH-4350 CD player (with remote control).
  • Alpine front splits.
  • Alpine Type R rear speakers.
  • 2 x 12 inch Pioneer Diamond Bullet subs in custom box.
  • Amp.
  • Insurance approved alarm with 6-point immob.
This car is running 170 RWKW on stock boost (tested at Boostworx). This car is perfectly set up for drift. With a boost controller and Power FC, this car will run 215-230 RWKW. I have not raced or drifted this car.
ANY INSPECTION WELCOME!
I have had an NMRA inspection conducted on this car within the past 10,000 KMs and the report found the following:
1. Limited service life left on all tyres.
A. Four new tyres and a wheel alignment 5,000 KMs ago.
2. No spare wheel sighted.
A. Space saver is located in the boot under the sub box.
3. Driver side central locking switch not working.
A. Disconnected as a common safety precaution.
4. Oil wetness evident at lower side of engine bell housing.
A. Rear main seal replaced by Tilbooks (SA) at cost of $400.00.
5. Minor cracks in front bar.
A. New front bar fitted with ZERO scratches and chips (at time of writing).
Tilbooks (SA) have serviced the car. I had a major service (including timing belt) conducted at 65,000 KMs just to be sure. This is a $1000.00 service for those not aware.
I service this car myself every 3,000 to 5,000 KMs. The car runs Motul 5W40 oil and Redline Lightweight Shockproof in the gearbox.
Registration until 01/06. No more to spend. This car is MINT. Come and have a look. I may be willing to trade. Please PM any trade offers. Feel free to post or PM any questions re. this car.
Car is located in Adelaide, near Glenelg. I am happy to send this car interstate at your expense.
Edited by P1E
https://www.sau.com.au/forums/topic/91793-modifed-r33-skyline/
  • 4 weeks later...
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
