I brought my car over my self through a broker in japan and i had Paul at autoworx comply it. Paul did an excellent job and i had no problems. Ive had the car on the road for 3 months now and i havent had a problem yet. if your interested in my broker PM me.
  • Replies 57
I did this also, best way to get a car into australia, thats for sure.
Wouldnt mind getting that brokers name 4door33? PM has been sent.
Have started looking around locally, so far everything has been automatic or with 140 000+ kms, GR! However, I will persevere! :) and keep an eye on the for sale section on the forum of coarse :( anyone wanting to sell a white manual r33 gts-t with lowish kms soon Im your lady! ;)
Autoworx...
No one else but him. Speak to paul there and he is an absolute champ. He also has a few R33's on his lot so check them out as well and I believe he would offer a warranty on his car's as well. He is a very honest man and when I recommended one of my mates to go see him about importing a silvia and plainly told him that because there were so many available locally that there was just no point in importing one. Very satisfying considering that if Paul had have said yes he would have gone ahead with it no worries at all.
But seriously go and speak with Paul and he will go through with you the con's and pro's of importing a vehicle vs buying one locally.
Autoworx are highly reccommended in my books.
Ahh yeah awesome! Yeah saving money is always a bonus! :P Yeah those were the only things I was worried about with importing thru Paul I mean I know he'd be able to fix up any problems I just dont want to get majorally burnt!!! And with work I didnt know how it'd be making the payments randomly.. but netbank would awesome
snip
When they state that the car imported is at 60k or 80k. Do you believe it? for a 10 yr old car to do 6k/yr or 8k/yr. Is it really possible? LoL.
snip
Abso-bloody-lutely I believe it. My previous R33 had done 33,000km when I imported it which equated to driving it at 4000km/yr. Just like KeeFy, a lot of people (not in the import business) told me it HAD to be fake, wound back, but EVERYTHING about the car indicated it was genuine - body, interior, mechanical condition, right down to the odometer reading stickers pasted in the door jam at each service interval.
Nelleh - The R33 I'm searching to import now (yes - through Paul at Autoworx as well) will not have any more than 40,000km on it. Having had one, I believe they ARE out there (just not lcally with low kms like that), just be prepare to wait for it to come around.
Not every car in Japan has done the same number of kms/year. Like I said - they are out there, but I'm sure the number of 8 year old cars with genuine low km's like mine had is small and if you want one like that, you HAVE to be patient. If it takes me 2-3 months to find another one like that, then so be it. Getting a car with 60-80K on the clock is much easier, but I reckon :
NEVER "settle" for a car. Get the one you WANT. :O
Meanwhile, my 1972 Mini Clubman is my daily racer :lol:
Edited by MearCat
I noticed that on the autoworx site they said they are working on being able to compile 32's. So does that mean theres a chance of bringing in an R32 sometime soon AND being able to get it registered?
I was under the impression that no more 32's would ever be allowd in the country and be driven legally on the roads after the 15yo rule was bannished?
A workshop in Perth is just waiting for an inspection in the next 2 to 4 weeks and they will be able to comply R32's (1992 plus) and compliance should be priced well but a lot more work goes into a car then the 15 year rule.
Some people made you think R32's will never be able to come in so you bought the 1989/19990 ones and did not wait for a later model car.
Some cars are already in Japan waiting to come in under RAWS so it is close.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
