Cubes,
If what you say is correct i will need to look into this quickly.
Just one question though, as you mention i didnt know that the normal trigger for the pump could shut down if the car stalled or such. Good to know really.
  • 5 weeks later...
Hi Guys,
This has been a really interesting read! I was hoping that you guys could clear up a few grey areas that i still have tho.
I am going to be running a bosch 040 or 044 pump inside my tank on my 32 GTR soon as i am upgrading the turbos and what not. My power aim will be around 320awkw and im wondering if this mod is required (as i know the pumps run approx. 230l/hr and 330l/hr respectively at 13.8v)?
Where abouts is the factory voltage control module located in the car?? Is it possible to rewire the pump but still use the factory voltage control module, as to only supply the pump with a lower voltage at idle but still have the 13.8v at higher rpm?? If not, im guessing the Jaycar kit that Sydneykid was talking about will be needed.
Thanks in advance for clearing it up for me.
Tony
I'm not sure about the other PFC's but when I dropped the PFC in to my R32 it constantly supplied the pump with high voltage. No more low voltage on idle with the PFC, In mine and other R32 GTST's I've seen.
I believe it would be possible to rewire the pump to still use the factory voltage control module. From memory I remember seeing something in the manual about the resistor pack to drop the fuel pumps voltage is located in the engine bay.
If its needed in your case.... suck and see... Unless you want to do it just to be safe and possibly save you having to go back for another tune, but chances are with a decent 044 even at the lowever voltage it will be fine. But really.. I don't know as there's a few variables that man influence if its up to the task, fuel pressure, boost and injectors size. Run less fuel pressure and the fuel pump will flow more.
anyone know what kind of current is drawn from the std fuel pump, same with the bosche 044 pumps?
with both of these running from direct power via a switched relay (each) finding its drawing alot of current making the car take longer to start
as in if i prime the system and turn the pumps off, then the car starts easier, then i switch the pumps on.
this is ona 550CA 60amp hour battery
  • 3 weeks later...
sorry about the late reply,
I would look at doing the oposite in your case and run larger cables to the starter motor. One thing that could be an issue is if your cables can not carry the current to run the starter motor, then the cable get hot during your start up, resistance of the cable goes up voltage goes down, then current goes up again! A very nasty circle.
Also a dircet cable from the negitive terminal to the engine block might help as well, if you dont have that already.
hmm its more ECU related than started motor ...
the dash lights go out when cranking then comeback on then the car starts
turning off the pumps just reduce the time the lights turn off for..
strange issue and i havent had time to play around with the currents that are being drawn when doing the above.
Strange,
does the starter motor sound like its struggling to turn the motor over. Do your self a favor if you have a multi meter connect it across the battery terminals and record what your minimum voltage was during the time your starter motor was turning over.
yeah will have a look, but no the starter turns the car over fine, just a momentary drop of power to the PFC
this is reduced further when jump starting the car..
can even get that bad if the battery is low that the car turns over but the lights never come on and it wont start ..
one day i'll find it
Have you had the motor out and rebuilt at any time?
May just be a bad earth.
motor hasn't been out, only ever head off..
have been looking into making my own earth kit for it all.... just a matter of free time which i dont have much of :D
only earth i know to be missing is the one the the turbo manifold.. which has been gone for years
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
