Item: 1995 r33 gtst
Item Condition: excellent
Reason for Selling: new car on the way, had my fun with this one
Price and Payment Conditions: $16000
Contact Details: email: [email protected] or call 0408977605
hey guys
my new hilux/low lux is being built and on the way, the 33 has to go, asap.
i bought the car in november last year, it had 115000 kms on it, it now has 125000kms on it.
only gets driven on weekends, if i have somewhere to go. otherwise it sits in the shed. has only been driven twice in the last 3-4 months though.
1995 ser 1.5 R33 gtst, 125000kms, 5spd, september '06 rego, has been serviced 4 times since i bought it, with Repsol Elite competition oil and genuine filters.
Exterior:
burgandy
400r front bar
Top secret skirts and rear pods
GTR wing
18x9 and 18x8 Work meisters
stretched 235/40 Dunlop Direzzas, 235/40 pirelli p7000 super sport
Suspension, Brakes:
KYB buzzspec coilovers
Pineapples
Cusco strut brace
RB74 pads all round
Nismo Braided lines
Engine:
No noises, compression and leak down test are good.
Garret T04, with internal gate, vg30det exhaust housing, comes on real hard at 4000rpm
GTR sized FMIC
Full 3" exhaust with tasteful cannon
Apexi Pod w/ Garage Debris airbox
Boost controller
Carbodix carbon button clutch plate, modified GTR pressure plate (3500kg clamping pressure), lightened flywheel (brand new)
Bosch 044 fuel pump w/ surge tank mounted in boot.
Gearbox and diff oils changed to Redline Shockproof wehn clutch went in.
Interior:
Nardi steering wheel (not sure if keeping this, but there will be a sports wheel on there)
Apexi Safc
Apexi Turbo timer
Apexi Boost gauge
Nismo gearknob (coming with me as it was a gift, will be a sports one though)
Pioneer Premier DEH860MP headunit, full colour screen, plays short movies, with stacker under seat and clarion speakers
front bar has a crack in it just under the headlight, has been stitched up with cable ties, the bandaid didnt work, looks tough i think.
thats about all i can think of at the moment,
wanted to build it up for drift, but was going to cost to much, and its too much of a nice cruiser the way it is, i couldnt bring myself to rip out all the interior and back seat, and pull the kit off,
heres some pics
$14000, 12 months rego, HAS TO GO ASAP!!!!!!!
cheers
Linton
Edited by NZM.031
no swaps sorry. trying to get rid of cars..
not sure on power as there is no dyno close by, it has been properly road tuned by Hunter Thomas Automotive.
it bags up second coming on boost, and sometimes third. it also gets to 200km/hr real quick, in 4th, still have 5th to go.
cheers
Linton
Edited by NZM.031
If I could sell my Stagea today - this is the car I would be buying :P I'll get back to you later if I can sell my beast...Till then, good luck with the sale
Cheers,
Chris
i used to be keen on a stagea... until i had a liberty wagon, stereo's really cut down the luggage room and in plain sight of anyone to see, pain folding seats down to put my bike in, and a pain to get the bike up on the roof. hence my going for a lowlux, can just throw muddy stuff in the back and it can be hosed out.
Farkskies thats cheap! Whoever buys this car is getting a dam good buy... Good luck with the sale, @ 14k you wont find another car with value for money.
Good luck with the sale mate, if I was in the market for a 33, definately worth taking a look at this.
Farrrrrrrk...... can i/we please have a picture of the front bar damage? And also one or two of the interior?
Im interested in this.....
Edited by ch0pstA~
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
