Item: K-Office Drift & Track Adjustable Coilover Suspensions For R34
Item Condition: Used - Just abit bouncy (may need re-gassing)
Reason for Selling: Want Stocks for R34 cause going back to stock.
Price and Payment Conditions: Trade for stocks & Pick Up $200/offers on top. Still For Sale
Extra Info: Height & Damper Adjustable. Trading only, $200 or offers on cash adjustments with trade of stocks. Trading only for the R34 GTT stocks. (Must be in good condition. Would prefer with lowered springs but other wise just plain stock) Car is off the road and still on the car, can be removed.
Contact Details: PM me.
There has been a mustake, these suspensions are not TEIN's but are "K-Office" as it was recently pull out and checked.
No pics as it is still on the car but car is of the road. Please dont PM me for pics.
Edited by FILO34
hey mate i have a set of low km stockies, but are the teins adjusable? and what adjustment do they give?
Hey buddy,
The TEIN's are adjustable,
Hieght & Damper, as far as i know of.
Do your stockies have any problems? how many kms?
does it have lowered springs?
Cheers mate.
no problema that i know of, out of an 8000KM old S2 wreck
Sounds good but is it S2... R33? cause im after R34 Stockers. Unless R33's would fit R34's but im not sure on that. But would rather prefer R34.
Cheers.
ive got a set of stockerrs on my r34. they come with lowered rsr springs as well. im interested in your coil overs. My only concern is i bought a set of 2nd hand coilovers a few years ago, put them on the car and they only lasted a few months before needing to be rebuilt. If you can guarantee that nothing is wrong with your suspension and i wont be needing any repairs to be done anytime soon. I will definately be willing to trade. you can contact me on 0424696113. cheers. oh and also i do have the stock springs as well as the lowered ones
  • 1 month later...
still for sale or trade......??
Items are K-Office not TEINs - just to let ppl know,
post has been edited.
R u still up for a trade. Cause i have got a set of bilstien shocks that are pretty stiff and standard hieght springs in my 34 4 door, r they inter changeable between the 4 door and the 2 door. would the K-office still be ok too drive round on for a bit. Do they need a service or a rebuild. just let me know on the cash adjustment. thanks mate.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
