Hi all
Every now and then I get a distinct burning rubber smell driving the car normally. It only hangs around for 5 seconds then goes away.
I am pretty certain its not the clutch as it doesnt smell like one and there doesnt seem to be a pattern. Note: this is normal driving, not harsh driving.
Any ideas?
https://www.sau.com.au/forums/topic/92892-burnt-rubber-smell-from-r34/
i fink it's from clutches man..
do u half clutch?
coz my mate used to hab rubber kinda smell after he drives when he didn't even drive hard..
but later i notice he uses half clutch a bit..
so yea..
try not to half clutch.. c if u get dat smell..
my r31 silohouette used to smell like burning rubber for a while when i put a 2 1/2" zorst on... there was a flap of rubber near the diff and used to smoke if it touched it... definately wasnt my clutch... i didnt worry too much on the assumption that if it does it enough the part thats touching will soon wear away and it did...
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
