hmm. please all correct me on this one, but i didnt even realise that 60 pounds of boost was possible without turning the engine into molten metal? (or some other serious damage anyway)...
whats the "ball park" limit before a car would decide its a goner?
and yes. i hate full-of-shit-gimps too...
I love it how ppl do that sh1te.
Some monkey claimed that they bought my car too on GTRCentral.
It was hilarious until someone caught them out and told me bout it.
KLASSIC!!
:lol: I don't blame him, u have a seriously kickass ride :)
Deviant: !Kuroi-Shi (#145852025)
Date: Jun 23, 2005, 7:55:58 PM
diffuser? i see none....but then again my current grafix card is below good and i can't see shit to well, if there is then yes it prolly works, unless kicked to many times.
Praise Nyarlothotep. And a big frikkin' middle finger to whatever Deviantart aneurysm messed with the other
enough sed really....
