bosimporting is where I got mine from. Michael is a champ - just PM him his nick is BATMBL - just let him know you're from SAU.
r32's use all sorts of bulbs - the one I installed in my flatmates car use H3/H3C's (same as cefiro). I've also heard of H1's being used to make sure you check before you order.
Just make sure you be careful with the high beams - the r32 high beams turn off the normal lights. This is NOT good for xenons. (I told my flatmate not to use his highbeams. He's happy).
You'll also be pleased to know silvia/skyline/cefiro projectors work very well with aftermarket kits and mine produce almost no glare and almost no hot spots - good ol' Nissan over-engineering.
Also - 4300k is the optimum colour - I use 6500k and that's just tingey blue.
https://www.sau.com.au/forums/topic/93109-xenon-lights/#findComment-1685137
I'm sacking the nissan projectors and retro-ing some Honda Euro HID projectors in... they're a bitch to do...
If anyone is interested, will post up some pics as I go.
Got the headlight apart at the moment, done some cutting of the euro HID projector and that's about it
https://www.sau.com.au/forums/topic/93109-xenon-lights/#findComment-1685210
This should probably go in DIY, but:
Headlight apart (sorry no glass pics):
Chrome headlight cover (being sprayed matte black) :D
Standard projector on left, Honda Euro on right (already cut an 'ear' off it)
As you can the Honda projector is shorter, and mounts further forward. Will have to fabricate a bracket for it to fit the standard adjusters... (in progress)
Cutting ears off Euro projector
Because the new projector sits so far forward in the assembly, i may have to cut the rear of the housing off and move it further back. If that's the case I'll plastic weld on a bit of PVC pipe with a press-fit lid on the back. Also, I need more diameter than the standard rear cap to get my fingers in to get the bulb out :)
I'm moving REALLY slow with this and probably won't get it done until xmas... so stay tuned
https://www.sau.com.au/forums/topic/93109-xenon-lights/#findComment-1688462
thats pretty cool about changing the pojector lights, but i can't be stuffed taking the time to do that
where does everyone buy their skyline light bulbs from? super cheap auto and repco don't have any that are the same as the jap ones.
i don't want to change it to hid or anything like that, i just want the brightest possible replacement bulbs, should i order them from nissan?
https://www.sau.com.au/forums/topic/93109-xenon-lights/#findComment-1691901
Nice work on the above. Good to see someone who will put in the time to try something new. Just becareful though because Xenon's are actually illegal here and so are modified lights that are not ADR approved. Not that any dumb cop is going to know the difference.
Edited by 3LIT3 FORS3
https://www.sau.com.au/forums/topic/93109-xenon-lights/#findComment-1692209
thanks elite - that's why I'm keeping them 'OEM' looking... by day no one would know any different except for the black surrounds instead of chrome :D
https://www.sau.com.au/forums/topic/93109-xenon-lights/#findComment-1692848
Update :cheers:
Inspiration struck... here is the old projector
Another view
disassembled
So i cut off the front lens side, so i can use the existing mount points, and just bond in the new projector :D
Trial fit :( is there nothing masking tape can't do??
back side
Trial fit again... stock you say...
Original...
New xenon trial fit ;)
Bored yet?? ...To be continued
https://www.sau.com.au/forums/topic/93109-xenon-lights/#findComment-1695889
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
