The same principle can be applied when reading your post.
What do you mean? Read your post outloud and see if it makes sense.
As for the thickness of the clutch plate itself, for what reason do you need to know as it may better help me to understand what info to give.
Are you just trying to work out whether the clutch is worn out or are you building some sort of custom clutch and, therefore, need specific measurements?
i guess i could have worded that a little differently, my appologies.
I'm asking how thick the total clutch disc thickness should be....my last clutch only lasted me 1500 km's. The last clutch was out of a Nissan Fairlady(300zx) brand new. This time i plan on having the old GTR clutch re-lined with ceramic.
ps. already searched for 2 hours on this site, no luck.
cheers
The total thickness of a GTR clutch plate is 8mm. This is made up in three parts, 1: The bonded material, 2: The centre plate, and again 3: The bonded Material.
Each bonded section is exactly 3.2mm thick
The centre plate is exactly 1.6mm thick
This makes a total of 8mm and is to suit the R32 GTR pull type clutch.
Hope this helps!
    • Order for the 2025 model R35 GT-R were accepted from 3rd March and 26th August the last order rolled off the production line at the Tochigi plant. Concerning the R35 GT-R replacement, current Nissan CEO Ivan Espinosa said "Nothing has been decided about the GT-R at this time, but we are well aware that everyone is waiting. The GT-R will evolve and reappear in the future. Please be patient until that day comes." Nissan has a lot of issues with management and finances so take Espinosa's words with a big grain of salt. From what discussions I've had and read about here in Japan, not a lot of people are confident about Nissan's future, let alone the next GT-R.
    • Thanks. We getting some parts along too so he will be solving the speed issue like next week so i will let you know what he came up with.
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
