  • Replies 277
Posted Images
I'm goin from the sunny coast however I am thinking I might tag onto the back of the cruise as it goes past me in caloundra rather than drive to bne then back the way I came and then out to Somerset  :)
What to the fellow Sunny Coasters think :(
Gives me chance to sleep in and save fuel  :lol:
Last year the cruise didn't follow the Bruce Hwy north to the Sunshine Coast - we headed north west from Aspley and came through the hinterland (out Woodford-Maleny way) to Lake Baroon... this year we aren't going as far north, and as far as I'm aware, we're still heading north west from Aspley (not via Bruce Hwy), so I'm not quite sure where in Caloundra we are going to pass you... ;)
I heard from one of my co-workers who is a member of FORDLASER.COM that there is a cruise out to Somerset on the same day for them. Might not hurt to hit them up for some donations also. I mean, I know they are not Skylines but they do have wallets and it is for the kids.
You are one hundred percent correct!
I agree with 85urk, that way we all start together and that way we dont get lost, left behind etc. if the main meet departure time is 10 then lets say meet at moby vics at 9 for a 9:10-9:15 depart which should allow us plenty of time to compensate for traffic. What u sunny coasters think
Edited by wessa02
Ok, local update!
It turns out that I forgot I have my anniversary weekend getaway with Katrina that same weekend.
So I guess I'll see you all there then hey!
I'm trying to convince her that we can leave early on sunday morning and meet up at the dam. I may have to crew up with the Goldcoast boys on this one.
Ok.. i think i was lost there...where's Moby Vic ?
how about all of the Sunny coasters meeting up at BP in Caboolture and all head down to Aspley instead..? wouldn't that be easier ? ( for me anyway :D )
say be there by 9am for the 9:15 depature ?
Those asking for a map of the route, yes I normally do this, and yes I will be. Please give me a chance to do so.
We will be heading out this weekend to do a scouting run and will hopefully (time permitting) have an itinery up for you on Sunday night.
I agree that the Sunny Coasters should probably just start the cruise from Aspley (c'mon guys, it's a bit of extra fuel and a little less sleep, but it's for the kids! :D ), but I'm cool with meeting up at whatever servo along the way... we'll just need to clarify which servo is which!
(which big one has Maccas/KFC/etc., and has a twin on the other side of the hwy?)
I agree that the Sunny Coasters should probably just start the cruise from Aspley (c'mon guys, it's a bit of extra fuel and a little less sleep, but it's for the kids! ;) ), but I'm cool with meeting up at whatever servo along the way... we'll just need to clarify which servo is which!
For all you Sunny coast cruisers
I'm for the BP as it has better coffee :):D:):blink:
Plus it has maccas and KFC
Plus better fuel and parking (flat)
How about we all meet there at 9am? or maybe 8.45 if we wanna eat ;) Whats the verdict?
I'm for the BP as it has better coffee  :)  :D  :)  :blink:
Sounds good to me... B)
sounds like a plan, which BP servo are we meeting at just to be 100% certain.  the moby vic side (heading towards brisbane) or or caboolture/beerwah side (headin towards the sunnycoast)
I would think the one on the east side (heading towards Brissy)...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
