Since everybody goes for the turbo engine swap, i thought i would do something different and supercharge my RB20de, the only thing is i dont know much about supercharging, things like will i need an intercooler? or a bov? or a waste gate? i havnt got the slightest idea. if any body can enlighting me on this topic i would very much appreciate it. + if anybody has any spare dash parts for the R32, give us a buzz, you might have what im looking for
Edited by Youngy
https://www.sau.com.au/forums/topic/94592-supercharging-rb20/
Adding a supercharger u can put an intercooler on it, and you can put a bov on it, except it not quite the same, its more so a bypass valve, does similar work but different name and minimal noise. Perhaps capa performance could help you with sizes of supercharger for you RB, you may need to look at your compression ratios to run it better, they should give you a good understanding and a rough power figure
it could certainly be done, but there is a lot to think about before you start. i'd use an Eaton M90 blower, don't worry about dropping the compression. fit large duration camshafts to get the head breathing better and drop your boost levels. then there's the hard parts: mounting and driving the blower. it's all custom work, and you either do it yourself or get a workshop to do it ($$$) properly.
use a cooler, it can't hurt.
use a bypass valve, not a BOV. if you're serious about doing it i can explain what this is to you, but you don't sound very serious about it at the moment. it's a much bigger job than you think.
do a search on some of the thread me and a couple of other guys did on supercharging RB's. We did came up with some good ideas, but in the end decided its cheaper, and easier to swap in a turbo engine. Especially on an RB20.
We figured it'd be easiest to use a supercharger off a Toyota 1G-GZE as its perfectly suited to the layout of an RB engine.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
