I've been doing a little research on Factory Cruise Control and it seems the only R33 GTS-T's that have it are Auto's. Can anybody confirm this. Does anybody in this Country actually have Factory Cruise????. I can get Aussie aftermarket stuff,,,but I really want Factory.
Thanks.
Neil.
https://www.sau.com.au/forums/topic/9479-cruise-control/
for some reason i dont think its only on autos, as the manual clusters are different than the auto ones, unless nissan did cut some corners and just manufactured the one speedo for both.
I do have the series II catalogue but unfortunatley the options page is in japanese.
https://www.sau.com.au/forums/topic/9479-cruise-control/#findComment-143387
Yea megalla's site might be right,,,But why does both my speedo's say "Cruise",,,and every R33 GTS-T have an extra place on the Inlet manifold bracket for an extra cable,,as well as the throttle body having a longer shaft to take another spindle. Why does the NZ owners handbook list it,,,,. It does exist,,,I'm sure of it.
Neil.
https://www.sau.com.au/forums/topic/9479-cruise-control/#findComment-143438
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
