Originally posted by GTR-80Y
Shut the hell up women!
Doesn't fox finish at like 3am or sumthin?
Pavillion hotel is ok......i saw that sexy assed D.3.V.I.L gettin down and dirty there on sunday night. Not too many good chicks apart from d3vil, but the music is good, usually RnB and Dance. I usually pop in on saturday or friday nights. Free entry is good too.
LOL u funnie Kient.....!!!
Pavillion rocks these days.... Crowd is good , music is good and the so many fine ladies around....
I'm back there tonite guys ahehehhehe..
Loz can u Pm me ur mob #..... chao....
https://www.sau.com.au/forums/topic/9486-clubbing/page/2/#findComment-146729
Originally posted by XrSiSt
Everyone has their own choice.. The crowd at Super Club was
great about 12 months ago, but as with everything everyones
getting sick of it so there's probably about half to three quarters
as packed only..
There are plenty of skanks.. i mean chicks there.. and yes i'd
recommend you line up with a girl or group of girls and don't
go in groups of guys... They won't let you in.. and yes it's from
experience.
Donnie.. we gonna blaze it up with S8TiN and FRYSKI?
I've seen S8TIN in parra 1 day- waved 2 da guy just drove past
https://www.sau.com.au/forums/topic/9486-clubbing/page/2/#findComment-148989
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
