Item: 18'' Volk SF Challenge, 18x8 front & 18x9 rear 235 & 265 tyres, rears useable, fronts are cactus!
Condition: Very good for age, some small marks, all centre caps etc
Reason for sale: Replacement wheels!
Price: $1400ono, prefer local pick-up & payment, can arrange o-wise
Extra Info: Note tVolk1.bmpVolk2.bmphese wheels have been posted elsewhere on this site for me previously by blaknite, will be removed asap!
Contact: 0412 776 276 - no PMs please! - may not be replied to.
Cheers,
Chris.
The pics are the actual wheels.
Not sure if they clear S15 brakes, but these clear my R32 calipers which is the biggest issue I've found getting wheels for my car. In short, if they clear my calipers I would expect yours are no issue (due to a 'kinder' off set). Happy to throw em on and have a try if you're genuine.
Thanks,
Chris.
  • 1 month later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
