when i get older.....
hi guys...im new here....just a few words...
1. when i get a GT-R.....itll have to be in like 10 yrs old....how much like new are they 140000ks down the road???....in terms of general feel, handling etc.... the thing is i would really like to buy one brand new completely stock but theres no chance any more aye??....
2. am i the only one that thinks japanese car makers are being gay by discontinuing all straight 6s......i swear the greatest sounding engines are L6s and V6s dont sound any where as good.......(RB , M3 etc)
3. insurance sux......its too expensive...just because im 18! i think insurance cover for me should be cheaper than the 40 yr old man on 40 grand per year who is angry cos he isnt successfull driver who sees cars as convenience and drives a falcon wagon and loves to tailgate and doesnt blink while changing lanes and......................
https://www.sau.com.au/forums/topic/9552-when-i-get-older/
1. Who knows? I don't think many people are driving even R32 GT-R's that have done more than that.
2. No
3. ****, if i'm on 40k when i'm 40 shoot me now :).. But..how many "old" angry drivers do you see on the roads?? I've never seen an old guy tailgate me ever.. I think the greatest complaint I can level against older drivers is the lack of concentration and "la de da ness" (own little world syndrome)
https://www.sau.com.au/forums/topic/9552-when-i-get-older/#findComment-144985
im just sterotyping the odd falcon wagon driver i know nothing about who is in a hurry to work doesnt blink when supposed to and generally a non educated (driver sence) bad driver
i hate most v6s ive been in.....especially my own....but generally i love the L6s have driven a gt-r my self once and listening to those m3s and supras and so forth
https://www.sau.com.au/forums/topic/9552-when-i-get-older/#findComment-144988
what??
agreed!
https://www.sau.com.au/forums/topic/9552-when-i-get-older/#findComment-146451
yes but he isnt flying down the street in his gtr is he. or wanting to drag race all the time
https://www.sau.com.au/forums/topic/9552-when-i-get-older/#findComment-146467
