Item: Rb26 Engine
Item Condition: Good condition
Reason for Selling: Project unfinished and run out of funds
Price and Payment Conditions: $5000 or $7500 with single turbo
Extra Info: see below
Contact Details: Brendan 0423 324 913, [email protected]
As i was unable to finish my rb26 project into my r32. I have put together a complete rb26 engine with or without turbo.
The engine consists of rb26 block, with full head, and sump, and with a custom made manifold to suit a GT3540 high mount. I will swap the manifold if need be to the single twin turbo one, but i dont have the turbos for that
Engine would consists of basically everything you need to drop this straight into a car. Engine will include brand new piston rings, brand new tomei metal head gasket 1.2mm. all pistons cleaned.
Whole engine cleaned ready to be used.
Prices: $5000 for engine with standard manifold no turbos
$7500 for engine with custom high mount manifold and GT3540 turbo and wastegate.
Will post interstate but at buyers expense
Located in Sutherland shire.
Edited by z3n2k
https://www.sau.com.au/forums/topic/95571-rb26-engine-5000/
would u like to swap for an rb25det head compelet wit r33 loom coilpacks etc.. but no manifolds and a hks T51 rated at 800-1000hp + cash on top?
Edited by JETR-32
https://www.sau.com.au/forums/topic/95571-rb26-engine-5000/#findComment-1730146
wat about a rb25/30det set up? and cash on top? if ur goin back to stock r33 and start from there this setup is unmoded u can start from scratch with dis... this set up is $1700 so if i give u $3300 on top for the rb26 wit no turbos + manifolds
let me know
cheers
bill
https://www.sau.com.au/forums/topic/95571-rb26-engine-5000/#findComment-1731524
Engine will consist of, brand new piston rings, cleaned pistons, comes with tomei 1.2mm metal head gasket, all new gaskets. Turbo is in perfect working condition. Engine should run fine with no turbos.
everything cleaned and put back in all working condition.
Basically stock engine but cleaned and put back together.
Will ship interstate if required but at buyers cose
https://www.sau.com.au/forums/topic/95571-rb26-engine-5000/#findComment-1732048
:( ohhhh.. in that case u should just buy an rb20de for a daily driver. u will get about 550-600km out of a tank wit that engine. it might have no balls but it will do the job
https://www.sau.com.au/forums/topic/95571-rb26-engine-5000/#findComment-1732104
tru if anyone can find a rb20det for my r32 rolling shell let me know.. :(
need to sell my rolling shell as well r32 gtst with no engine
and i dont have the time to drop the rb26 into the r32
https://www.sau.com.au/forums/topic/95571-rb26-engine-5000/#findComment-1732109
ive got a rb20det compelet has done 92xxx km's on it. runs like a dream. serviced every 5000ks.
if u want to swap for the rb20det for the rb26 wit cash on top let me know.
cheers
bill
https://www.sau.com.au/forums/topic/95571-rb26-engine-5000/#findComment-1739031
    • Hmm makes things tricky then.  I can't in good faith say, go forth my child and weld in whatever metal you remove in your quest for rust. I very strongly expect that adventure will end in sadness.  But you can't leave the car as it is, you literally have a hole in the roof. Also, I know you think the rust doesn't go much further, but the more I look at those photos, I really think the rust does in fact go much much further.  If you are 100% committed to being the only person working on the car.... stop where you are, hit it with rust converter, fiberglass, body filler, paint work, pretend you never discovered the rust in the first place?  Even if the body was repaired, painting the roof is a pain. Were you planning to use rattle cans to paint the roof?
    • Ok so I will not defend my naivety. I regularly feel like things look easier than they are.  As much as I'd love to, buying another vehicle is out of the question. It was hard to get this car through the family process and we just don't have the room.
    • If your current chain of thought is, I'll go somewhere like pick and payless (or equivalent) and causally remove the bit of roof with your BYO grinder then casually weld that into your car... oof. It might sound easy but you will 100% end up with a warped roof. You say you'd prefer some ugly fab work, but I don't know if your prepared for how ugly this will be lol.  I've seen professional welders do similar but easier repairs and still end up with warped panels.  It is reasonable to assume that from your current skill level, you won't be able to do this cut and paste job while keeping flat panels.  Ok, but we are here to learn. This might be the go... jump on car sales, sort by price, buy the cheapest thing with rego and drive it home. This is your new practice vehicle. If you're thinking of doing the cut and paste job, try it on this car. Cut out the panel (hey it's a perfect fit) weld in the panel. See what you think of the results.  Next thing you could try, practice removing the entire roof in one piece by drilling out all the spot welds etc. Have a crack and welding the roof back on.
    • I've never welded but I own a welder and I've always wanted to learn. In fact I had already looked at a 1 day welding course in Sydney.  I'd prefer some ugly metal fab than anything weak.  I'm challenging myself a lot with this car. For so many years I've just paid other people to do things and I've always been keen to learn and get better.
    • Ok, thats a good starting point.  So before we start.... do you mind if the car say isn't a strong as it was before? My first thought is go excavating for rust. You'll be left with a gaping hole, that will be filled with fiberglass. You could make it look factory pretty easily but yeah, if you never crash it will never be an issue right? Before we look at other options, how confident are you welding?
