Item: Black R33 GTSt25T Type M 1993
Item Condition:Great (new paint)
Price and Payment Conditions:$17,500 ono
Extra Info:Car comes with:
Apexi Filter,
Titinum exhaust turbo back
Tein HA, Apexi turbo timer
Face lift to series 2 with lip
GTR front mount intercooler
New water pump , timing belt and fan belt
Stock R33 wheels with Grid 3 tires.
New paint recently done by Mirror Finish
Tinted windows
Alarm with shock sensor
MP3 JVC player
Car done 95000km
Heavy duty clutch
Skyline Front and rear Strut tower brace, adjustable
Factory bodykit
Contact Details:Email me at [email protected] or pm me for more information.
Edited by Sky_nismo
https://www.sau.com.au/forums/topic/96190-black-r33-rb25det-gtst-1993/
  • 2 months later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
