hey guys. i have a R32 GTR which me and a mate recently pulled off the inlet manifold and throttle bodies to change the gaskets as they were all leaking. now even though everything appears to be back in the right place i no longer can achieve 14 psi boost. instead all it is giving me is 9 psi boost which feels soo slow :P .
is there anyone out there who has had a similar problem? i cannot see how ( with the restrictor removed ) i can receive less boost than before when i had leaks everywhere. the car runs so much better now and idles properly but i am left with this problem ;)
please help
kermit
https://www.sau.com.au/forums/topic/96269-lost-my-boost/
what gaskets are we talking about exactly, i think the boos is were it should be ,but when you had leaky gaskets it was boosting more but looksing it, but i am no gtr guru so i may be wrong but i think 9 pound sounds right though, hope i was of some assitance
https://www.sau.com.au/forums/topic/96269-lost-my-boost/#findComment-1745228
we replaced the inlet maifold gaskets and the throttle body gaskets. all surfaces were cleaned and permatec ( gasket goop) was used both sides of the gaskets.
removing the restrictor in the boost line is supposed to give 14 psi ( or close to it). which according to my boost gauge i had before the gaskets were changed.
kermit
https://www.sau.com.au/forums/topic/96269-lost-my-boost/#findComment-1745261
Hi, yeah I have the same problem. My gtr produced just over 14 PSI, had the turbos rebuilt, now only 12 PSI??
Replaced actuators, no difference. I also have both restrictors removed???
I would like to know what boost the turbos are actually producing. Is it only 12PSI or is there a leak and only 12 gets to the manafold but the turbos are working harder. Remember the boost guage reads manafold presssure not turbo housing pressure. I'm still working on the problem. The workshop who did the turbos seem to have done a good job. Everything refitted correctly and nice and tight. <_<
hey guys. i have a R32 GTR which me and a mate recently pulled off the inlet manifold and  throttle bodies to change the gaskets as they were all leaking. now even though everything appears to be back in the right place i no longer can achieve 14 psi boost. instead all it is giving me is 9 psi boost which feels soo slow  :wacko: .
is there anyone out there who has had a similar problem? i cannot  see how ( with the restrictor removed ) i can receive less boost than before when i had leaks everywhere. the car runs so much better now and idles properly but  i am left with this problem :P
please help
kermit
https://www.sau.com.au/forums/topic/96269-lost-my-boost/#findComment-1752115
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
