Item: Prof BOV and intercooler pipe to suit R33
Item Condition: Used
Reason for Selling: Upgraded to HKS Sequential
Price and Payment Conditions: $70 for the BOV by itself or $110 including custom blue intercooler pipe with fitting.
Extra Info: Will only sell with the intercooler pipe if you can trade in your stock pipe. Prof is a popular and quality brand and this BOV is well made and has adjustable spring tension. Ran fine on my 33.
Contact Details: PM or email me - [email protected]
https://www.sau.com.au/forums/topic/96275-prof-bov/
