seen it the other week, got no pics, but god damn its beautiful, and if it had 2 sunroofs id buy it and swap my gear into it.
series 2 black, factory recaros, rims, lowered, looks crazy with clear taillights, and xenon headlights.
someone go down and get it, or atleast some pics of it.
best stagea ive seen to date besides the r34 front ended ones :)
cheers
Brad
https://www.sau.com.au/forums/topic/97074-black-staj-at-autowholesale-yard/
I have ALWAYS loved black cars, my last car, r33, was black, until I frankenstiened it up.
Black cars look awesome, until they get dirty, which is about 3 seconds after you was it!!
Still black stag with that black tint with some nice black rims, dumped, mmMMmmMmm noice!!
I like it a lot, but try keeping it so clean and shiny..........
I am actually glad I have the gunmetal grey, cant really tell it's slightly dirty from a distance.
Still once I owned a gold car, it never looked dirty :D
But you know what they say, once you black, you never go back! :)
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
