Item Condition: All items in excellent condition, unless noted otherwise
Reason for Selling: Items were either replaced or not used during recent upgrade
Contact Details: PM or reply via this thread
Brand new items - still in box, never used
* HKS Duralumin Adjustable Cam Gear (Exhaust) - SOLD
* Bosch 040 in-tank Fuel Pump - SOLD
Used Items - off 97 Series II GTS25T
* Std R33 Turbo (no shaft play, works perfectly) - SOLD
* Std R33 Turbo heatshield - $30
* 3" dump pipe (bought new from BATMBL approx 6 mths ago - practically new) - SOLD
* Std R33 Fuel Injectors - SOLD
* Std R33 Ignition Coils (suit series II only) - $250
* Std R33 Fuel Pump - $50 - SOLD
* Std R33 AFM (series II) + piping - $100
* Std R33 BOV - $60
* Std R33 Exhaust Manifold + Heatshield - $100
* Std R33 Engine Mount (average condition) - $20
* O2 Rush Performance Panel Air Filter (suit Std airbox) - $50
* Std R33 Gearknob - SOLD
Used Transmission Items - originally off an RB20DET, but were on my car at time of purchase
* Rb20det Gearbox (excellent working order) - SOLD
* Rb20det Tailshaft - SOLD
Items are located in Sydney and inspection can be arranged if necessary.
Local pick up is preferred, but freight can be arranged at the buyers expense.
All reasonable offers will be considered (ridiculous offers won't get a reply).
Cheers,
Brenden
https://www.sau.com.au/forums/topic/97135-assorted-r3332-parts-new-used/
interested in rb20det tail shaft..... wot will it cost to send it to adelaide?
Sorry mate, not sure on postage - I'm guessing around $20-$30 as it is fairly heavy. I'll make enquiries at the post office if you are keen.
May I have a big pic of the gearknob please?
Willing to sell the slave cylinder from the gearbox if it's original?
Cheers!
Here's a larger pic - sorry it's a bit blurry. Gearknob is in perfect condition.
Gearbox is now sold pending payment.
As for the shifter, can you do it for $50 shipped? I'm in Sydney, Northern Beaches.
Cheers!
$50 is fine Randy.
I'm also in Sydney (Parramatta/Hills area) if you'd prefer to just pick it up, although I'm happy enough to send it to you.
Let me know how you wish to proceed.
Cheers
Brenden
  • 4 weeks later...
Hey buddy was wondering if you have any front body parts for sale like front and rear reinforcer (metal behind the bumper), condensor, horn, radiator support, bonnet catch etc...
If you do please email me at [email protected] and attach your phone number
thanks!
thanks!
Sorry mate, i've only got the stuff listed at the moment
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
