hi people im selling my T51 turbo i never had the chance to blot up this monstar, i Brought this puppy about 1month ago it was goin to go on a Rb 25/30det. but my plans have changed to a rb26dett with twin hks 2830 pro s turbos. im Located in melbourne i will be able to post anywhere, it will cost $80 to post coz its 20kg's
i paid $2000 and selling for $1300frim*
Spec's
T51 Turbo rated at 800-1000hp
Checked by ATS turbo professionals, who said it was in very good condition.
No shaft movement (Bush type Turbo)
Oil cooled only
HKS Stamped on rear housing
Garret Tag on the Centre of the turbo
Garret Front cover
-Compress wheel is 7cm across A/R .72
Front compressor bell mouth 10cm across
-Exhaust Wheel is 7cm across A/R 0.90
T4 Flange
Serial number on turbo - WG 7011J
Comes with Dump/front pipe to suit
Edited by JETR-32
https://www.sau.com.au/forums/topic/98037-fs-hks-t51/
  • 3 weeks later...
to bolt this turbo up to an rb20 it will need alittle work. frist u will need to buy a T3/T4 Adaptor plate from autobarn about $30 to blot the turbo up to the standard Manifold. then u will need to cut a hole in the Manifold and weld up a small pipe for the wastegate (all this can be done at anywork shop for no more than $100) for the dump/front pipe i have one and will give it 2u for free. blot up the oil lines and off u go. about a dayz work if u get help.
Hi.  Sorry to sound like an idiot, but how much work would I need to do to put this onto a rb20det with 3" intake/dump, and 500hp fuel pump?  Everything else is pretty stock.
https://www.sau.com.au/forums/topic/98037-fs-hks-t51/#findComment-1847547
hi i enquired about this a while ago, the dump pipe/and front pipe bolt up to the cat on my gtr? or do i have to get a pipe made up.
Do you have access to a manifold to suit a rb26? and wastegate?
hi mate the front/dump pipe is for a high mount but can be modifly by any shop. for the manifold and wastegate talk to "RACESPEC" on this forum he can hook u up with a package. if u get a high mount manifold the dump/front pipe will bolt rite up
https://www.sau.com.au/forums/topic/98037-fs-hks-t51/#findComment-1851215
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
