$$$$$$$$$$$$$$$ 19,950 o.n.o $$$$$$$$$$$$$$$$$$$$$$$$$
1990 R32 GTR
79,000kms
imported in sept 05
sept 06 rego
79,000kms
2ND GEAR IS BLOWN. CAR STILL DRIVES, BUT NOT ADVISEABLE TO DRIVE. REBUILD WILL COST ANYWHERE BETWEEN $1000~$2000. PRICE IS NEGOTIABLE, ALL OTHER GEARS STILL DOING FINE!
white with gold pearl
nismo rear wing, no GTR wing
18inch deep dish rims
original tape deck
momo steering wheel
automatic turbo timer, pivot.
3 point immobiliser
alarm
keypad entry
high flowed turbo's running 13psi
3inch exhaust
twin plate clutch - unknown brand
bilstein suspension
235rwkw
car runs very well, and is very quick
excellent condtion... very nice car!
$19,950 o.n.o
need to sell, cant afford insurance, running cost and maintenance much longer.
i am a "P" plater and insurance is costing me $5900 per year.
call me on 0401 664 828 for an inspection or any enquiries.
thankyou
Edited by Giffo
https://www.sau.com.au/forums/topic/98412-r32-gtr-1990/
mate i only have one picture of the car sorry.....
yeah im looking at getting a 200sx, cheaper insurance the car is newer, and less hassles from police, being on p plates!!
and thats what my dads wants me to get!!
cheers!
https://www.sau.com.au/forums/topic/98412-r32-gtr-1990/#findComment-1788537
bumpo..... willing to take tv out and put stock tape deck in.... and then the car can go for $23,300
open to offers but nothing ridiculous......
car is immaculate, and looks very nice with the gold pearl over white..
cheers...
https://www.sau.com.au/forums/topic/98412-r32-gtr-1990/#findComment-1798801
car is still for sale, some one must want a beautiful looking GTR which is very quick considering the mods!!
i cant afford to keep this car too much longer...
new price $$$23,300 ono$$$
sold my touch screen tv to a mate..
offers thanks
https://www.sau.com.au/forums/topic/98412-r32-gtr-1990/#findComment-1800772
Swap for thirty three: Mint nick: Rare factory option Gtr v spec rear diff. I bought car 4 months ago from impoorter. Since have put on 400r front bar, fmic, pod, turbo back exhaust, 18 inch deep dish rims, PFC + hand controller. ie spent 29000 all up in 3 months!
190RWKW and 320 nm torque. Im about to lose my licence and am looking for a new project prefer GTR. TO get 300 RWKW just need bigger turbo and cams!
https://www.sau.com.au/forums/topic/98412-r32-gtr-1990/#findComment-1811816
bump, car is still for sale and im asking $22,150!!!
please feel free to call, any inspection welcome, no test pilots!
genuine buyers only thankyou..
~~~as some-one just F***ed me around! he will knwo who he is!!
thankyou!!
Garth.
https://www.sau.com.au/forums/topic/98412-r32-gtr-1990/#findComment-1846312
bumpo.....
come on guys, some-one must want this car, its immaculate, fairly cheap, and really fun to drive, would make an awesome weekend car, if some-one can afford to do that!!!
any inspection or enquiry welcome, if genuine!!!
cheers....
https://www.sau.com.au/forums/topic/98412-r32-gtr-1990/#findComment-1849185
how about your dreaming!! GTR with that amount of power for 19...
go elsewhere buddy!!
u can have it for 19 without the turbo's, without the tv, without the bonnet?!?!?!
and yes the car is legal. apart from the pod filters! and gearknob doesnt have the "H" pattern on it!
bump...
https://www.sau.com.au/forums/topic/98412-r32-gtr-1990/#findComment-1909887
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
