All the SCOOP on SWOOP!!!!
  • Replies 143
Guest Austin Powers
Hey Jimbo, I'm thinking about getting a gemini for $500. Do you think Prosperion will approve me. I have good financial record. Here is my credit history for your financier to evaluate.
1. in 1992, I borrowed $5 from my sister and paid her back 2 weeks later.
2. Austudy busted me for not living away from home so I paid back my away from home allowance in 5 years plus interest.
3. I took $2 from a begger in the street but gave $5 to the church the following month.
4. Me mum still owes me $25, so in terms of net value, I'm worth $25. (shit, I forgot, I still owe my dad $50, so that puts me in negative)
That is an awesome credit record dude. I have no debt and I paid back everything I take. :)
1. in 1992, I borred $5 from my sister and paid her back 2 weeks later.
2. Austudy busted me for not living away from home so I paid back my away from home allowance in 5 years.
3. I took $2 from a begger in the street but gave $5 to church the following month.
That is an awesome credit record do. I have no debt and I paid back everything I take. :)
I think you should just stick to your fullee sick echo :uh-huh:
:bahaha:
Yes Dr...but if pain persist, can should I come see you?
Ed, you on de dole and you driving an R34.....and cops fly.
Dr, what you do? Speaking of sugar, I'm at work at de moment sipping my tea with 3 sugars. It's gud shit.:)
you obviously haven't been to centre link before :)
:bahaha:
Guest Austin Powers
you don't scare me off that easy. I'll take you on and your biceps...SWOOP might envy them but I have my chopsticks to defend myself. LOL.
But anal, that is something i would be scared off. I aint pushing no shit up stream man or no one is pushing my shit up the chocolate runway.
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
