Item: Various, see below.
Item Condition: Excellent
Reason for Selling: Taking up space, no need for them
Price and Payment Conditions: Buyer pays postage
Extra Info:
Contact Details: PM me here, or email [email protected]
Have a few things for sale:
Go Fast Bits Atomic Boost Controller (Manual) - GFB3001
Brand new in box, Blue in colour.
Single stage, under bonnet adjustment.
Includes allen key and hose.
Pic: http://www.gofastbits.com.au/index.php?par...b_option=atomic
$55 ono.
PM or email me for more details.
Thanks,
Nath
Edited by NathR32
  • 3 months later...
I still have the original boxes for the sub and amps.
HVYMTL: PM replied
clincha: Yes I also have a Autometer Dual 2" Gauge Pillar Mount to suit R32 GTS-t and GTR. Excellent condition. $70
  • 1 month later...
  • 3 weeks later...
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
