FOR SALE
1989 Nissan Silvia S13 Coupe
ENGINE
RB20DET ECCS version
new bottom end satndard internalls
full VRS gasket kit only 9000 kays ago (head gasket,rear main ect..)
new thermostat
new hoses
coils replaced 2000 kays ago
new engine mounts
gearbox mounts
motul turbo oil fully sinthetic
ENGINE ACCESORRIES
T4 turbo made by IHI / Borg Warner
bradied oil feed line
Custom Manifold
Exernall Tial wastget 35mm 10psi spring
Custom 3 inch dump
custom 3 inch exhaust,3inch high flow cat, magnaflow muffler
K&N filter
300x700x75 intercooler
custom piping
silicone hose joins
R32 GTR pump
malpassi rising rate fuel pressure reg
R32 GTS t Radiator new top and bottom tanks
twin 11inch electric thermo fans with thermo controll switch
catch can
DRIVELINE
Xtreme heavy duty button clutch
relpaced full tail shaft and universals
GTS type M brakes
Bendix ultimate pads
motul 5.1 brake fluid
1998 Nissan patroll Master cylinder (brand new)
ABS
SUSPENSION
front
Kie office fully adjustable coil overs (hieght camber and dampner)
rear
koni shocks adjustable dampner
pedders low springs
nolathane stabaliser bar
top strut mount bar
urathane bushes all round
WHEELS
17 inch gunmetal grey speedy rims
near new tyres
BODY
brand new respray black with red and blue pearl
OT front bar
unknown side skirts
jetspeed rear bar
tinted windows %18 lifetime warranty
INTERIOR
Momo imitation wheel
auto meter boost, oil pressure, Air Fuel Ratio meter
AXS seat covers
STEREO
kenwood head unit WMA,MP3 ect..
kenwood front splits 6 inch
kenwood rear 6 inch
kenwood 800watt 2 channel amp
kenwood 430 watt 4 channel amp
kenwood 1200watt dual voice coil Db+ SUB
ect...
BRIEF
sorry for the long winded description
i just wanted it all there
this car has taken me a year and a half to build 12 months off the road then 6 months on
im selling it as i have lost the goal i set out to achieve
i built this car to be driven and of late i have neglected it as i only drive it to work and back like 5 blocks away
its just not practical anymore and is going to waste not being driven
dont get me wrong i love it to death its like my very own child i made and raised
it just needs someone who will love it as much as i DID
some of you know ive had a hell of alot of problems when i first bought the car
everything and i mean everything is 100% no word of a lie
the car has basically been built from the ground up
so i know everything abouth the car
im asking 19,000
i know it might sound step but i think its well worth it as i have spent probably double thati will negotiate but not to far as im not that ken to get rid of it
make a serious offer i will consider swaps for a more family car nothing Australian
like Ford OR Holden
i dont know what else to say
please ask as many questions as you want ill answer all and ill also add in the descrption when i remember more thing ill note then with a *
thanks for your time
cheers
matt
some photos below i have bout 200 photos from start to finish of all the things ive done i can email some to people but ill try set up a gallery and link it
here are some more important ones
at this time im only replying posts and emails will do the phone thing when someone is real interested
email
[email protected]
Edited by blackrb20silvia
https://www.sau.com.au/forums/topic/98584-s13-rb20-19000/
yeah 003
but the car has been built from ground up again since that was done i bought it from a guy who bought it from a guy...lol that used to work there but the state it was in when i bought it well you can have a look at my previous posts to find the cars history
but cheers anyway
https://www.sau.com.au/forums/topic/98584-s13-rb20-19000/#findComment-1801759
no way have a look at any decent 32 or s13 near stock they are round 12,000
to many mods to let it go for that id rather keep it
id consider offers around 17,000
https://www.sau.com.au/forums/topic/98584-s13-rb20-19000/#findComment-1801944
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
